Number of Route Pattern for CCM
Hi folks,
can you tell me, how many Route Pattern I can insert in CCM?
Thanks a lot
Klaus
Blue
Re: Number of Route Pattern for CCM
There is no hard set limit on CallManager for the number of Route Patterns.
How many Route Patterns are you talking about?
adignan - berbee
Hi adignan and all other experts!
problem is that we have a GSM gateway and this don´t support numbering portation. So it means, that you make a call via GSM gateway you are running in higher costs than via normal ISDN gateway because you dial the number from one GSM provider but the number belongs to another provider and this has much more costs.
I don´t know exactly how many numbers the customer will insert but it can go up to many ~1000 or more.
Is there any problem?
Thanks for help
Klaus
111
