Community Member
On VoFR which codec is suitable for compression
I have to configure VoFR , the host location has 2 PVC each with 16 K CIR with 56 K access link --which codec would be good default 729ar8 offers 8 K for once voice channel plus the over heads for frame which is 7 bytes and with 2 voice channels 16 K woul dbe enough.
What is the appropriate way of calculating the voice bandwidth requirement, I know one formula
required bandwidth=codec(1+overheads/payload size)..
so if this the right one, overheads are for frame then what is payload size here.
Anonymous
N/A
Re: On VoFR which codec is suitable for compression
you need to consider VAD and header compression,etc,
so for g729 with VAD and header compression, one call normally
consume about 11-12 k.
Community Member
There are no header compressions on VoFR only vad can save you more bandwidth and the choice of codec and payload size on the codec ofcourse. For VOFR , a g729r8 call is a 10k compression and here is the calculation below:
Bandwidth=codec rate *[(payload_size+overhead_size)]/(payload_size)
For example for 8kbps g729:
Bandwidth=8k * (30+1+2+4)/(30)=9867pbs ~ 10kpbs
(with 30byte payload_size, 33.3 ms frame interval)
So for 2 vofr g729r8 calls you need about 20k.
Hope this helps.
116
