one screen presentation problem on calls pass through cube
hello all,
may I have your advices about following problem;
this is flow diagram:  cts codec (site A)  --  >>  cube  -->> cts codec  (site B)
if the codec in the site B is one screen as cts 1100 the presentation cant be shared bidirectional.
however if it is 3 screen as cts 3010 the presentation works fine.
this is the part of config:
voice service voip
 ip address trusted list
  ipv4 X.X.X.X
  ipv4 X.X.X.X
 rtp-ssrc multiplex
 address-hiding
 allow-connections sip to sip
 redirect ip2ip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  session transport tcp
  rel1xx disable
  header-passing
  early-offer forced
  midcall-signaling passthru
  pass-thru headers unsupp
  pass-thru content sdp
  sip-profiles 1
  copy-list 1
voice class codec 1
 codec preference 1 aacld profile 1
 codec preference 2 g722-64
 codec preference 3 g711ulaw
 video codec h263+
 video codec h264 profile 2
 video codec mpeg4
voice class sip-profiles 1
 request INVITE peer-header sip Contact copy "(;video;audio;x-cisco-tip;x-cisco-multiple-screen=3)" u01
 request INVITE sip-header Contact modify "$" "\u01"
dial-peer voice X voip
 destination-pattern X...
 rtp payload-type cisco-codec-fax-ack 126
 rtp payload-type cisco-codec-fax-ind 110
 rtp payload-type cisco-codec-aacld 96
 rtp payload-type cisco-codec-video-h264 112
 session protocol sipv2
 session target ipv4: X.X.X.X
 voice-class sip bind control source-interface GigabitEthernet0/0xxx
 voice-class sip bind media source-interface GigabitEthernet0/0xxx
 codec aacld profile 1
Everyone's tags (1)
Hi Onur, I have bumped to
Hi Onur,
I have bumped to this discussion and having the exact issue.
Do you manage to solve it? If yes, can you please share on how you solve it?
Thanks in advance.
Hithis case still open and in
this case still open and in progress in TAC.
When it is fixed I can share it.
Hi Onur,Thanks in advance.
Hi Onur,
Thanks in advance.
hi fantasy24in your problem
hi fantasy24
in your problem you faced, have you tested 3 screen endpoints?
is there any problem with them?
and is it possible to share your current devices and versions that are being used during the call?
thank you.
Hi Onur, 3 screen endpoints
Hi Onur,
3 screen endpoints work fine.
CTS3010 (1.9.6)
CUCM (8.6.2)
CUBE (15.4)
hithe problem is still alive
hi
the problem is still alive on my site and TAC couldnt find any problem.
how is the life on your site?
still on?
Hi,It is still the same.Could
Could you please provide all the equipment detail so that I can compare?
Thanks.
it would be fine.MSE 8710  4
it would be fine.
MSE 8710  4.0.2.8
VCS x8.1.1
CUBE 3945 15.1(4)M5
cucm v9
hiyou have any string asvoice
hi
change it with
 request INVITE peer-header sip Contact copy "(;video;audio;x-cisco-tip;x-cisco-multiple-screen=*)" u03
 request INVITE peer-header sip Contact copy "(;video;audio;x-cisco-tip;x-cisco-multiple-screen=(.*))" u03
 request INVITE sip-header Contact modify "$" "\u03"
it will work.
Do you mind to share your
Do you mind to share your full configuration?
I can't get it to work.
Thanks.
169
