One way audio Extension Mobility transfer
We are using CCM 3.3(3) SR2 Extension Mobility and H.323 Gateways.
Problem description:
A call from PSTN is answered by a user (extension mobility), this call will be transfered to another ip phone. the next user (extension mobility) is answering and he is hearing the the PSTN Caller but the Caller (PSTN) hears ring tones and not the ip phone user.
Any ideas?
thanks in advance
August
Silver
Re: One way audio Extension Mobility transfer
Sometimes using the command "h323-gateway voip bind srcaddr" causes one way audio. Check the bug CSCdw69681 for more details.
Thanks for your answer.
The failure in my case was a bug in the IOS software of the voice-gateway.
August
217
作成コンテンツを作成するには してください
