ONE WAY AUDIO WITH A CISCO 2800
I have a Cisco 2800 like a voice GW, making a Trunk SIP with a Asterisk PBX. I don't know the Asterisk configuration. My GW is used only to external calls, using a PRI port.  We have problems with calls since 10 days ago:  I can make a call but the called can't hear me and I hear him.
I need some help about this problem. I attach logs with differents debugs
This is the 2800 configuration:
_CAT_CONTAC_CENTER#sh run
Building configuration...
Current configuration : 8823 bytes
version 12.4
service password-encryption
hostname _CAT_CONTAC_CENTER
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
dot11 syslog
ip cef
no ip domain lookup
isdn switch-type primary-net5
trunk group  E1-0/0/0-1
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service pots
voice service voip
allow-connections sip to sip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
voice class codec 1
codec preference 1 gsmamr-nb
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 ilbc
codec preference 5 g723ar53
controller E1 0/0/0
pri-group timeslots 1-31
controller E1 0/0/1
description Conexion al Switch
ip address XXXXX 255.255.255.0
ip access-group Control-Sip-desde-Asteriskin
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no isdn outgoing display-ie
trunk-group E1-0/0/0-1
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXXX
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip access-list extended Control
permit udp host XXXX host xxxx eq 5060
permit udp host XXXX host xxxx eq 80
permit ip any any
ip access-list extended Control-Sip-desde-Asterisk-Nuevo-acceso
remark Permitir Trafico SIP desde la centralita Asterisk
permit udp host XXXX host XXXX eq 5060
permit udp host XXXX host XXXX eq 80
remark Denegar Otros Intentos de Conexion SIP
deny   udp any host xxxx eq 5060 log
deny   udp any xxxx 0.0.0.3 eq 5060 log
remark Permitir Acceso Gestion
permit ip any any log
access-list 80 permit XXXX
control-plane
voice-port 0/0/0:15
cptone ES
timeouts call-disconnect 0
timeouts wait-release 1
voice-port 0/0/1:15
cptone ES
dial-peer voice 1 pots
trunkgroup E1-0/0/0-1
voice cut-through alert
description XX
destination-pattern .........
progress_ind alert enable 8
progress_ind progress enable 8
incoming called-number .
clid strip
direct-inward-dial
forward-digits all
dial-peer voice 2 voip
description Llamadas internas VOIP Asterisk
shutdown
voice-class codec 1
session protocol sipv2
session target ipv4:XXXXX:5060
session transport udp
no vad
Everyone's tags (3)
1 REPLY
Re: ONE WAY AUDIO WITH A CISCO 2800
Issue is being troubleshot via:
https://supportforums.cisco.com/message/3211360#3211360
Locking this thread as a duplicate.
2743
