one-way audio
Hi, I have a:
ATA 186 with Version: v2.14 ata186 (Build 020521a)
IPPhone 7905 with Version: v1.0.h323 ld(020603b)
Cisco C2610 with Version 12.2(11)T8
When I make a call from ATA 186 or IPP 7905 I experience a one-way audio only. If I run a show call active voice brief command on cisco gw I see that rx packet are equal to 0.
2F10 : 24574558hs.1 +295 pid:1 Answer 78255155773 active
dur 00:00:08 tx:436/8720 rx:0/0
IP 200.69.228.57:16384 rtt:0ms pl:0/0ms lost:0/0/0 delay:70/70/70ms g729r8
2F10 : 24574562hs.1 +291 pid:122 Originate 04284618 active
dur 00:00:08 tx:0/0 rx:437/8740
Tele 1/0/1 (148): tx:8740/874/0ms g729r8 noise:0 acom:2 i/0:-40/-82 dBm
I don`t have a problem with networking or NAT, the three cisco devices are in the same LAN. If I use the IOS 12.2(8)T5 I don't have any problems.
The question is:
Is there a bug in ths Cisco IOS 12.2(11)T8 or do I need to make a new consideration in the configuration?
Re: one-way audio
3 commands that may help:
global:
voice rtp send-recv
under an interface:
h323-gateway bind
h323-gateway interface
Please see:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
Re: one-way audio
I all ready have this commands in the configuration and the labs is in the same LAN, the rarely is if I use de IOS 12.2T5 it’s works fine, the problem is with the IOS 12.2(11)T8. My doubt is if it's a bug or I need to take a new consideration whit this IOS. I search in the cisco web but I don’t see nothing about this.
127
