Community Member
One-Way Conversation on Outbound FXO
Need help with one-way conversation on outbound calls to the PSTN using FXO.
I have UCM 7.1.5.10000-12
Router/Gateway is 2811 with a VIC2-2FXO card and PVDM2-8
Router and UCM are connected via a point to point T1
Router is setup as H323 and voip bind is configured on interface
Internal point to point - router to UCM calls are fine, placing external PSTN calls from location/router to UCM are fine, external calls from UCM to router are fine, external calls to the FXO port - POTS line (plar to extension) are fine
BUT
Calls made from the router to UCM and back out on the router FXO POTS line receive one-way conversation.  You can hear the called party, but they cannot hear you.
I am at a lost.  I've checked all configuration and I am not seeing anything.
Does anybody have any ideas?
Mel
Hall of Fame Super Gold
Re: One-Way Conversation on Outbound FXO
Even with the interfaces voip bind set, still there is a routing / addressing issue.
One would have to look and take traces to find which one.
Community Member
So what traces need to be looked at? I did a "voip ccapi inout", but I don't think I saw anything wrong.  There is lots of information and very possible I am missing what I need to be looking for.
Can you let me know what traces and what I need to be looking for?
Mel
319
