Community Member
One-way issue using cRTP in the WAN
Anybody knows what means this message?
This message happens WHEN:
1. First we just has one-way audio,
2. Then the compression mechanism resynchronize
3. Finally then the call works fine.
1. ONE-WAY AUDIO
*Jun 26 21:29:21.309: IPHC(UDP) Se0/1/0.1 DLCI 124: CS 3 IPCRC incorrect
SYNCHRONIZING IP HEADER-COMPRESSION
*Jun 26 21:29:21.309: IPHC(UDP) Se0/1/0.1 DLCI 124: Invalid sequence (cs 3, recv. 12, exp. 5)
*Jun 26 21:29:22.429: IPHC(UDP) Se0/1/0.1 DLCI 124: CS 3 rate limited resync
*Jun 26 21:29:22.441: IPHC(UDP) Se0/1/0.1 DLCI 124: CS 3 rate limited resync
TWO-WAY AUDIO
*Jun 26 21:29:33.653: IPHC(UDP) Se0/1/0.1 DLCI 124: Ignoring UDP packet (3031->389)
*Jun 26 21:29:33.657: IPHC(UDP) Se0/1/0.1 DLCI 124: Ignoring UDP packet (3031->389)
*Jun 26 21:29:33.833: IPHC(UDP) Se0/1/0.1 DLCI 124: Ignoring UDP packet (3031->389)
*Jun 26 21:29:33.837: IPHC(UDP) Se0/1/0.1 DLCI 124: Ignoring UDP packet (3031->389)
Community Member
Did you ever find a solution for this?
I have hit on the same problem. I am trying to use SIP signalling with IOS 15 on remote router. I experience the same one-way audio problem, coincides with the same error.
In addition, I also a "failed to fastswitch" error
Oct 01 13:14:18 10.130.186.30 5652: Oct  1 13:14:19.230: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:18 10.130.186.30 5653: Oct  1 13:14:19.246: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:18 10.130.186.30 5654: Oct  1 13:14:19.250: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:18 10.130.186.30 5655: Oct  1 13:14:19.262: IPHC(UDP) Se5/7.1 DLCI 100: CS 0 IPCRC incorrect
Oct 01 13:14:18 10.130.186.30 5656: Oct  1 13:14:19.262: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:18 10.130.186.30 5657: Oct  1 13:14:19.266: IPHC(UDP) Se5/7.1 DLCI 100: CS 1 IPCRC incorrect
Oct 01 13:14:18 10.130.186.30 5658: Oct  1 13:14:19.266: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:18 10.130.186.30 5659: Oct  1 13:14:19.286: IPHC(UDP) Se5/7.1 DLCI 100: CS 0 IPCRC incorrect
Oct 01 13:14:18 10.130.186.30 5660: Oct  1 13:14:19.286: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:18 10.130.186.30 5661: Oct  1 13:14:19.290: IPHC(UDP) Se5/7.1 DLCI 100: CS 1 IPCRC incorrect
Oct 01 13:14:18 10.130.186.30 5662: Oct  1 13:14:19.290: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:19 10.130.186.30 5663: Oct  1 13:14:19.302: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:19 10.130.186.30 5664: Oct  1 13:14:19.306: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:19 10.130.186.30 5665: Oct  1 13:14:19.326: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
Oct 01 13:14:19 10.130.186.30 5666: Oct  1 13:14:19.326: IPHC(UDP) Se5/7.1 DLCI 100: Failed to fastswitch
I changed the config slightly to try to fix. Before I was using FR traffic shaping:
policy-map WAN-EGRESS-512/512-8CALLS
class VOICE
  priority 318
   compress header ip rtp
  class class-default
   fair-queue
   random-detect
map-class frame-relay Voice&Data-512/512-8CALLS
frame-relay cir 512000
frame-relay bc 51200
frame-relay be 0
frame-relay mincir 512000
service-policy output WAN-EGRESS-512/512-8CALLS
int s5/7
frame-relay traffic-shaping
int s5/7.1 point-to-point
frame-relay interface-dlci 100
  class Voice&Data-512/512-8CALLS
I changed this to
policy-map VOICE&DATA-512/512-8
class class-default
  shape average 512000 5120 0
  shape adaptive 512000
  service-policy WAN-EGRESS-512/512-8CALLS
interface Serial5/7.1 point-to-point
frame-relay ip rtp header-compression periodic-refresh
service-policy output VOICE&DATA-512/512-8
(it's essentially the same, only I moved from FR traffic shaping to MQC and put compression on the interface direct instead of the policy-map)
Same result, but the periodic-refresh seems to shorten the error time to 2 seconds. (This option was not available in policy-map command)
Did you by chance resolve? Was this to do with a mismatch of IOS version in the connected routers?
I found this bug:
Cisco bug  CSCsd91454
RTP calls get disconnected when cRTP enabled
Symptom: Person 'A' and 'B' speaking. At some random point during the call, person A would stop being able to hear person B, person B would still be able to hear person A and if the call was put on hold, then resumed, both would be able to speak and listen normally till this happened again. Conditions: Have seen the issue on links with 768k bandwidth Workaround: Disable cRTP
Unfortunately we are running low capacity sat links and need to squeeze every drop of b/w. disabling is not really an option.
Many thanks
Phil
Hall of Fame Super Gold
The bug shows;
Fixed-In Fixed-in
12.4(4)XC6
12.4(4)XC7
12.4(4)XD5
12.4(6)T6
12.4(9)T3
12.4(11)T
12.4(11)XV1
12.4(12.3)T
12.4(12.4)PI6
12.4(6)XE3
12.4(11)XJ5
12.4(22.3.4)PIC1
12.4(24.5.2)PIC1
If you are running software newer than that on both routers, you will have to contact TAC and open case.
399
