one way transmission and PSTN gateway
I have request the gateway problem again. because of IOS version install in Vg200, I have upgrade the new version 12.2(15)T5 in the Vg200. The pervious version have the one way transmission and inital silence. but the new version can not solve the one way transmission. Does the version be bug ??? Because i have found all bug about 12.2(15)T5.
On the other hand, I use the version 12.2XN install at vg200. I config to MGCP. As once time, the gateway loss the data connection. The gateway can re-register to callmanager. But the call route is not common. I see all the call can not route this gateway but the call comes in is right ??? Is it the bug ???
Re: one way transmission and PSTN gateway
Please Help Me to reply my question.
It is two questions. THX
Bronze
do you pressing any dtmf keys during the connection ?
May be this issue:
Bud ID: CSCea80147
hope this helps
mehmet
106
