one way voice call
I have a wan sistem so configured:
One lan with Call-manager,3 ip phones,2 analog phones,connected by fxs port, and 1750 router.
Another lan with 2620 router and 2 ip phones.
The two lan are connected by serial connection.
When I make a call from the IP phone in 2620 lan to the ANALOG phone in 1750 lan, there is only one way voice, from analog to ip, but no from ip to analog.
Has someone any idea to resolve this problem?
Thank in advance
Lorenzo
Re: one way voice call
Can you post the config of the 1750?
This is 1750 configuration.
version 12.1
no service timestamps debug uptime
no service timestamps log uptime
hostname XXXX
enable secret 5 $1$sxpM$EkKMSywcEo6jLxfGPiXTU0
memory-size iomem 20
ip subnet-zero
no ip finger
ip audit notify log
ip audit po max-events 100
cns event-service server
voice-port 1/0
cptone IT
voice-port 1/1
cptone IT
dial-peer voice 401 pots
destination-pattern 004
port 1/0
dial-peer voice 402 pots
destination-pattern 005
port 1/1
dial-peer voice 601 voip
destination-pattern 007
codec g711alaw
session target ipv4:173.23.XXX.XXX
dial-peer voice 602 voip
destination-pattern 009
codec g711alaw
dial-peer voice 603 voip
destination-pattern 0..
codec g711alaw
session target ipv4:192.111.111.111
interface Serial0
bandwidth 64
ip address 100.100.100.2 255.255.255.0
no fair-queue
clockrate 2000000
interface FastEthernet0
ip address 192.168.240.248 255.255.255.0
speed auto
h323-gateway voip interface
h323-gateway voip h323-id 192.111.111.111
ip classless
ip route 173.23.XXX.XXX 255.255.255.0 100.100.100.1
no ip http server
line con 0
transport input none
line aux 0
line vty 0 4
password cisco
login
end
Tanks in advance
Try configuring this:
h323-gateway voip bind srcaddr 192.168.240.248
under the FastEthernet0 interface. Then make sure that the 1750 is defined as 192.168.240.248 in the CallManager configuration.
Ok.Thank you wery much!
With this command it works, but on relese software that is on 2620 router, so I changed the configuration lab.
Have you any ideas in what release software for 1750 router can I find this command?
Thanks in advance!
Lorenzo
Ok
I find the right release for 1750.
Tanks again
Lorenzo
140
