ONE WAY VOICE ISSUE H.323 Gateway
I have a 2610 configured as a h.323 gateway. It register with my gatekeeper. I am experiencing one way voice from the 2610 h.323 gateway to another h.323 gateway. Note the gatekeeper and gateway are on different networks but I have established IP connectivity. I can ping each router on the different networks successfully.
Here's what I have configured on the 2610.
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname chi-voice1
enable secret xxxxxxxxxx
ip subnet-zero
ip dhcp-server 10.0.0.1
call rsvp-sync
voice rtp send-recv
voice service pots
voice service voip
fax protocol t38 ls-redundancy 1 hs-redundancy 1
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g723r63
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 1
translation-rule 1
voip-incoming translation-rule called 1
interface Ethernet0/0
ip address 10.0.0.25 255.255.255.0
no ip route-cache
no ip mroute-cache
half-duplex
no mop enabled
h323-gateway voip interface
h323-gateway voip id gk-sj ipaddr 206.79.131.25 1719
h323-gateway voip h323-id chi-voice1
h323-gateway voip tech-prefix 4#
h323-gateway voip bind srcaddr 10.0.0.25
ip default-gateway 10.0.0.1
ip classless
no ip http server
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 206.79.131.0 255.255.255.0 206.79.131.77
voice-port 1/0/0
voice-port 1/0/1
input gain -6
station-id name chi-voice1
station-id number 5178881
dial-peer cor custom
dial-peer voice 1 voip
destination-pattern 5178882
voice-class codec 1
voice-class h323 1
session target ras
fax rate 14400
no vad
dial-peer voice 4 pots
destination-pattern 5551111
port 1/0/0
no register e164
dial-peer voice 5 pots
destination-pattern 5178883
port 1/0/1
gateway
gatekeeper
shutdown
Re: ONE WAY VOICE ISSUE H.323 Gateway
See the following link for troubleshooting one way audio issues
http://www.cisco.com/warp/public/788/AVVID/fix_1way_voice.html
See if that helps.
We had occasionall one-way audio problems on AS5300, but we solved it with IOS upgrade.
Nikola
Can you send the output of "show call active voice brief" during the call?
1165
