Community Member
One way voice issue on CallManager 4.0(2a)es26
I have some few ip phone 7940g/7960g in the same partition.
When the user make a call ( from partition X ) to another ip phone ( to partition Y ), the calling can not hear the called, however the called hears well the calling. and when a ip phone from another ( partition Z )make a call to ip phone ( partition X ) the calling can not hear the called also the called hears well the calling.
The callmanager running 4.0(2a)es26.
The ipphone load is 7.0(2)
Many thanks
christophe/
Re: One way voice issue on CallManager 4.0(2a)es26
Typically one way audio issues are going to be IP Routing issues. If the two phones that experience one way audio are on different subnets start by verifying the IP routing between the two phones.
Kevin
Community Member
hi,
As pointed out by Kevin already this might be an issue with IP routing between subnts. This link will give you a better understanding of one way audio issue-
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a008009484b.shtml
rgds,
subhrojyoti
Community Member
Thanks for your reply.
The problem occurs only with internal calls( ipphone to ipphone, not with external calls
thanks in advance.
regards,
Christophe
Community Member
hi christopher,
can you please verify me that these are 7960/7940 ip phones. i hop these are not softphones ! are the phones in different vlans/subnets and please check that inter vlan routing is running correctly. this looks like a routing issue since partition and css doesnt come into play after the call has been established.
rgds,
subhrojyoti
Community Member
As stated my shubrojyoti, it clearly not a partition or css issue. If you had one, then calls would not have connected in the first place.
Find out if its happening with perticular set of phone. try isolating the issue. If possible add two new phones with similar configuration and check if the issue persists.Getting a sniffer trace from the back of the phone will give more ideas.
Venky
105
