One way voice transmission issues
I have two 3640's connected via a serial HDLC point to point circuit. Both routers can ping and telnet each other and have full data connectivity. However, the problem is when router A calls Router B, the calls connects, but the voice can only be heard inbound, no outbound voice is heard at the remote end. When Router B calls Router A, the calls are perfect in both directions. In addition both sites can communicate with 3 other VoIP enabled sites without any problems, they just can communicate with each other (in one direction). Router A has an E1 and uses ISDN QSIG Router B has a T1 and uses E&M signalling. Any light on this very strange problem would be much appreciated
Both routers are running IOS 12.1(5)T10
1 REPLY
Anonymous
N/A
Re: One way voice transmission issues
Sounds like the answer supervision is not sent back to A correctly. Check on that.
Also you can try putting the following command in:
voice rtp send-recv
357
