One-Way voice using MGCP to access 911
This might be a simple fix but I'm currently stumped. I'm setting up a 2610 to handle my 911 outbound calls. I'm using IOS Version 12.2(8)T5 (c2600-is-mz.122-8.T5.bin).
I created a duplicated route pattern for 911 so I do not call the authorties if you know what I mean.
Here's the issue: when I call the emergency pattern, the call goes through but I cannot hear the other party. I can see the through the phone there is outgoing traffic but no receive packets. I'm using MGCP to the 2610 router. Here is the config:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname XXXXXXXXXXXXXXXXX
enable secret xxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip subnet-zero
no ip routing
fax interface-type fax-mail
mta receive maximum-recipients 0
ccm-manager switchback graceful
ccm-manager redundant-host x.x.x.x(ccm1)
ccm-manager mgcp
interface FastEthernet0/0
ip address x.x.x.x(cisco2610 ip)255.255.255.0
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
ip default-gateway X.X.X.1
ip classless
ip http server
ip pim bidir-enable
call rsvp-sync
voice-port 1/0/0
voice-port 1/0/1
mgcp
mgcp call-agent X.X.X.X (CCM2)service-type mgcp version 0.1
mgcp restart-delay 60
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
application mgcpapp
port 1/0/0
line con 0
line aux 0
line vty 0 4
Re: One-Way voice using MGCP to access 911
Try enabling ip routing. Even though you are not routing, The VoIP subsystem in in IOS uses IP routing code to help encapsulate and transmit VoIP packets. From config mode just type ip routing
Figured it out. Inserted defualt route.
89
