Community Member
Oneway voice issue from ip phone to ip phone
I am having intermittent one-way voice issues from ip-phone to ip-phone located on the same segment. No WAN connection or gateway located in between the phones. We are using 3524pwr switches. Can anyone shed some light on this issue?
Community Member
Re: Oneway voice issue from ip phone to ip phone
It might be discrepancy between codecs - for example, you are using codec G.723r53 on the one side and G.723ar53 on the other.
Community Member
The problem is intermittent and resetting the phone seems to take care of the problem. It is also not just one phone. The problem seems to travel. The phone system has been installed for about 3 months. The problem has been occurring for the last 2-3 weeks.
109
