Community Member
OS 2.5 upgrade problems
Ever since upgrading to OS 2.5 + SR1 I have been getting the following error in the application log of my publisher (the subscriber seemed to upgrade fine)..
Anyone have any ideas on this?
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 9/5/2003
Time: 2:04:56 PM
User: N/A
Computer: PPSLOPS-CCM1
Description:
Error: GetNewFileName-fopen2=NULL
1 ACCEPTED SOLUTION
Bronze
Re: OS 2.5 upgrade problems
Try this:
1.Stop Cisco Call Manager NT service.
2.There should be a file called "DBL~num.bin" under c:\program files\cisco\trace\dbl please rename this file to "DBL_num.bin.xxx" size will be 1k
3.Using notepad create empty a file and name it as "DBL_num.bin" file size 0k
4. Now start "Cisco Call Manager" service.
Bronze
CSCec19813
Symptom:
The following error is logged in the application event viewer:
Event Type: Error
Event ID: 3
Date: 9/2/2003
Time: 10:40:06 AM
User: N/A
Computer: XXXXXXX
Description:
Error: GetNewFileName-fopen(ffileNumberfile)=NULL,error=0x.
This error is seen ~300 times.
Condition:
This has been observed in CallManager version 3.3(x) after a reboot of the server. The condition is not seen when the CallManager service is stopped/started.
Workaround:
Verify the existence of an MA folder in the trace folder:
C:\Program Files\Cisco\Trace\MA
Community Member
Thanks for the quick response, but the workaround doesn't seem to apply to me. I have a MA folder in the trace folder and it is collecting data.
Any more ideas?
Gordon
Bronze
Try this:
Community Member
This did it! Thanks.
Community Member
I'm getting this problem again on my publisher. The bug notes say that this is a CCM problem... does anyone know when this will be fixed?
Community Member
I am having the same problem on a subscriber. The publisher is fine. I have tried the recommendation in one of the earlier posts to no avail. I have also verified the existence of the MA trace file directory. Any other ideas?
145
