OS versions
What is the difference between OS 2000.2.7 and 2000.4.2? Is there any difference if I use 2.7SR8 and apply all the hot fixes individually or use 4.2SR6?
Thanks, Glenn
Green
Re: OS versions
2000.2.7 is not going to have anymore SRs. 2000.4.2 is the OS release going forward for all platforms.
Yes there is a difference, certain platform update, bios updates, check the RN for details.
The 4.2 OS train is the recommended one, so 000.4.2sr6 is the latest recommended OS release.
//G
Re: OS versions
Also for new installations, 4.2 takes a lot less time than the 2.7. You dont need to enter CD keys, change discs etc.
Bronze
Re: OS versions
If I have 2000.2.7sr8 now.
Can I upgrade to 4.2 now, then 4.2sr6??
Ken
Re: OS versions
Ken,
Yes you can do that!
I just did an upgrade the same route yesterday!
96
