Outboud calls failure
Hello
I am using CME 3.4 on a Cisco 3725 router with IOS 12.4(4)T3.
Inbound calls are correctly treated, but I cannot make outbound calls (tests made from line 66). The message "incorrect number is displayed".
Here are some portions of the configuration :
dial-peer voice 1 pots
destination-pattern 0T
direct-inward-dial
port 1/0:15
forward-digits all
telephony-service
dialplan-pattern 1 012345.... extension-length 4
ephone-dn 66 dual-line
number 5641
The command csim start [number] also failed.
Could you please help me ?
Thank you a lot.
1 ACCEPTED SOLUTION
Silver
Re: Outboud calls failure
You must precede with "voice". For example:
old way
(config)#translation-rule 1
new way
(config)#voice translation-rule 1
The "old way" still works but does not support regex like it appears that you are trying to do.
-mike
PRP
One more thing, also it seems that old syntaxes for translation-rules no longer work, do you confirm thye change. I still did not found anything on cisco.com (example : rule 1 /.+/ /0123456789/ is not accepted)
Silver
old way
new way
-mike
PRP
Silver
The "forward-digits all" command will send the leading 0 to the PSTN and cause the call to fail.
-mike
-Please rate post, Thanks.-
Thank you all,
The numbering in France needs a 0, so it should be kept.
I will perform the tests by tomorrow morning with voice tranlation-rule..
I made the tests with the correct command for translation.
I tested translation and it works but still outbound call are failing (even with csim start).
Are there any debug commands I can use to troubleshoot the problem ?
Thank you for your help.
That's ok : I got the correct number of PRI timeslots from the provider and now, it works !
Thank you.
Silver
Glad you got it working. Please remember to rate helpful posts!
118
