Outbound call issue
I have a 2851 setup as an h323 gateway. I have outbound/inbound calls working with the exception of 911 calls. The call goes through, I an hear the 911 operator, but he cannot hear me. Below are some portions of my config.
thanks in advance for the help!
Adam
voice-port 0/0/0:0
voice-port 0/0/1:2
dial-peer voice 200 voip
destination-pattern 6...
progress_ind setup enable 3
session target ipv4:10.249.32.1
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
ip qos dscp cs5 media
no vad
dial-peer voice 101 pots
destination-pattern 9011T
direct-inward-dial
port 0/0/0:0
prefix 011
dial-peer voice 102 pots
destination-pattern 91T
direct-inward-dial
port 0/0/1:2
dial-peer voice 103 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:0
dial-peer voice 203 voip
destination-pattern 5......
codec g711ulaw
fax rate disable
no vad
dial-peer voice 204 voip
session target ipv4:10.249.32.2
codec g711ulaw
fax rate disable
no vad
dial-peer voice 104 pots
destination-pattern 911
direct-inward-dial
port 0/0/0:0
forward-digits all
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: Outbound call issue
Problem resolved... Forgot the h323-gateway voip bind srcaddr....
122
