outbound caller id - PRI - CCM3.3.3 - H323 gateway
I getting closer on this PRI but it's not quite there yet. I can't get outbound caller id to work. The ISDN switch type is primary-ni. Variance in NI2. I have the gateway configured as H323. Outbound calls work but the caller ID data is not sent.
Below id the q931 debug output:
*Mar 4 19:13:24.105: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x000B
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '3212833'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '1237281'
*Mar 4 19:13:24.213: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x800B
*Mar 4 19:13:25.061: ISDN Se1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x800B
Progress Ind i = 0x8288 - In-band info or appropriate now available
*Mar 4 19:13:31.933: ISDN Se1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x000B
Cause i = 0x8090 - Normal call clearing
*Mar 4 19:13:32.213: ISDN Se1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x800B
*Mar 4 19:13:32.225: ISDN Se1/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x000B
Any ideas?
Patrick Brown
Re: outbound caller id - PRI - CCM3.3.3 - H323 gateway
Debug show that you are sending the Caller ID '3212833' to Telco. Does your PRI provider has caller id to pass through his side?
You may want to change your caller id representation to 10 digits instead of 7 digits.
I tried to change the caller ID to 10 digits and now I don't see the calling party number in the debug. I changed the Caller ID DN from a format of 12345XX to 206XXXXXXX. When I change it to 20612345XX it works. I have two different blocks of DID numbers so I need the first (206XXXXXXX) to work.
Patrick Brown
644
