10-31-2006 08:16 AM - edited 03-13-2019 03:36 PM
hi all,
Q1.) With refer to belows, I hope the "Calling Party Number i = 0x0081, '33800' " should appear '8883800' ?
Q2.) I hope my mobilephone will display 8883800 instead of just the extension number 33800 as you seen belows.
Any idea how to do that? please advise. thank you very much.
Here's the sample debug isdn q931
*Jul 23 06:09:37.733: ISDN Se1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x03A9
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Display i = 'Spsn IT Regional Helpdesk'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0125667835'
10-31-2006 10:25 AM
Check the External Phone Number Mask configured for the DN in CCM admin. Also, make sure that your route patterns have the "Use Calling Party's External Phone Number Mask" box checked.
Hope this helps. If so, please rate the post.
Brandon
10-31-2006 06:17 PM
external phone number mask configured at ccm ? if the mentioned already ON ?
11-01-2006 05:19 AM
Are you saying that the external phone number mask was configured or asking how to configure it? You can configure the mask by:
1. Go to https://ccm ip address/ccmadmin
2. Go to Device -> Phone
3. Find the phone that you want to change
4. Click the phone and then click the DN
5. Enter a value for External Phone Number Mask
Also, are you saying that "Use Calling Party's External Phone Number Mask" was already checked on your route patterns?
Brandon
11-01-2006 11:11 AM
hi brandon,
For line 5.
* the pilot number is 8882000 . So i'll assign 888XXXX .
Am i right?
11-01-2006 12:55 PM
Yes, if you assign an external phone number mask of 888XXXX and the DN is 3800 and you check to use the calling party's mask on your route patterns, then 8883800 will be sent out to the PSTN for this DN.
Brandon
