outbound calls fail intermittently using H323 and FXO to PSTN
Running CCM 4.21, H323 gateways on 2811 ipvoice 12.4(4)T. Eight FXO ports connected to Verizon Centrex lines. Intermittently, when making an outbound call Cisco IP phone shows dialed number and call seems to be proceeding but after about 9 seconds IP phone goes back on hook. Never see connected, or hear ringing. If you redial 2 or 3 times the call goes through. You can see the call hitting the same FXO port. Below is output of first call failing and second call proceeding. Anyone ever see this before?? Saw similiar post that suggested overlapping dial-peers but to me mine look good??
Comm01Lewvr1#sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x18E8 3321 0x45BAC178 0/1/3 0/1:1 *95233009 None 1/16
1 active calls found
0x18E8 3321 0x45BAC178 0/1/3 0/1:1 *95233009 g711ulaw 1/16
Also, see below example of outbound dial-peers. each FXO has the same three dial-peers each set has a different preference. Also, sh call history shows the failed call as "normal call clearing"
dial-peer voice 16 pots
destination-pattern 9[2-9]......
preference 2
port 0/1/3
forward-digits all
dial-peer voice 17 pots
destination-pattern 91..........
preference 2
port 0/1/3
forward-digits all
dial-peer voice 18 pots
destination-pattern 9911
preference 2
port 0/1/3
forward-digits all
1 REPLY
Green
Re: outbound calls fail intermittently using H323 and FXO to PST
If you can replicate the problem can you upload the debug voice ccapi inout
and the detailed CCM trace.
200
