Outgoing calls disconnects on first attempt - MGCP setup
I need some help or insight on the ff please:
1. Some of my outgoing calls disconnects on first attempt - this however doesn't happen on all calls (Happens unexpectectedly).
2. I can't hear called party's respond to the call for the first few seconds = this happens on some of the succesfull calls.
3. I at times fail to hear called party at all, even though they claim they could hear me when i retry calling them.
This issue started few weeks ago, everything used to be okay. I have tried the ff with no luck:
- mgcp reset
- shut and unshut the serial port
Below is my site configs (remember, this used to work just fine until few weeks back - no changes were made):
version 12.4
service password-encryption
hostname RTR1
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 16384
no aaa new-model
memory-size iomem 10
clock timezone SAST 2
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
dot11 syslog
ip source-route
ip cef
ip domain name xxxx.net
ip name-server 10.0.0.57
ip name-server 10.0.8.4
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
fax protocol cisco
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
class-map match-any qos_CS2
match ip precedence 2
class-map match-any qos_mail
match access-group 122
class-map match-any qos_voice
match  dscp ef
match protocol rtp
class-map match-any qos_sce
match access-group 125
class-map match-any qos_rdp
match access-group 121
class-map match-any VOICE-SIGNALLING
match protocol mgcp
match protocol skinny
match protocol h323
policy-map xx-QoS
class qos_voice
    priority 112
   compress header ip rtp
class class-default
    fair-queue
     random-detect
policy-map yy-QoS
class qos_voice
    priority 240
class VOICE-SIGNALLING
    bandwidth 10
class qos_CS2
    bandwidth 100
   compress header ip tcp
class class-default
    fair-queue
     random-detect
policy-map LS-QoS
class qos_voice
   drop
class class-default
    fair-queue
     random-detect
policy-map Bothas-QoS
class qos_voice
    priority 48
    bandwidth 10
class class-default
    fair-queue
     random-detect
policy-map FB-Qos
class qos_CS2
    bandwidth 100
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn send-alerting
isdn sending-complete
no cdp enable
p http server
no ip http secure-server
ip flow-cache timeout active 1
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination 10.0.0.224 9996
access-list 121 permit tcp any any eq 3389
access-list 122 permit tcp any any eq smtp
access-list 125 permit tcp host 10.0.0.54 any time-range Peak
dialer-list 1 protocol ip permit
voice-port 0/1/0:15
echo-cancel coverage 24
cptone ZA
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.x.1.2
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.0.x.x
ccm-manager config
mgcp
mgcp call-agent 10.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp ip qos dscp cs3 signaling
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 10.x.x.x identifier 2 priority 2 version 4.1
sccp ccm 10.x.x.x identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register TRN0013192d73a0
associate profile 2 register MTP0013192d73a0
associate profile 3 register CFB0013192d73a0
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 8
associate application SCCP
dspfarm profile 3 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions hardware 8
maximum sessions software 250
gateway
timer receive-rtp 600
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
login local
scheduler allocate 20000 1000
ntp master 10
ntp update-calendar
time-range Peak
periodic weekdays 6:00 to 17:59
periodic Saturday 7:00 to 15:59
end
If there's any post relating to this - please attach it hear because i've been searching for over a week with no luck.
Super Bronze
If there's no change to this gateway then there may be something in between you and the gateway that has changed.
When on a call, pull up the call stats (on a 794x or 796x or similar, press ? twice quickly). If you have lost rx packets, then something is interrupting the RTP stream. Think firewalls, ACLs, etc.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
523
