Outgoing calls problems
Hello I can make any call from my PBX to my IP Phones but when I want make any call from my IP phone to my PBX it doesn't work.
I get this error
Router#csim start 74801
csim: called number = 74801, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(179)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
My configuration is
controller E1 0/0/0
pri-group timeslots 1-31
interface GigabitEthernet0/0
description subinterface IP Telephony
ip address 20.20.20.1 255.255.255.0
duplex full
speed 100
media-type rj45
interface Serial0/0/0:15
no ip address
isdn switch-type primary-qsig
isdn incoming-voice voice
no cdp enable
voice-port 0/0/0:15
cptone VE
timeouts call-disconnect 2
timeouts wait-release 2
description Telefonia IP PDVSA
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern .T
direct-inward-dial
port 0/0/0:15
Do I am missing anything...
I appreciate your help
Leonardo
Re: Outgoing calls problems
Can you please run this debug and include the result here.
term mon
debug isdn q931
You should see something like this for calls originating on the router towards the PBX:
2651XM-Informatica#term mon
2651XM-Informatica#debug isdn q931
ISDN Q931 packets debugging is on
2651XM-Informatica#
Sep 28 18:09:48.094: ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x6307
Sep 28 18:09:48.094: Bearer Capability i = 0x8090A3
Sep 28 18:09:48.098: Channel ID i = 0xA9839D
Sep 28 18:09:48.102: Facility i = 0x91AA068001008201008B0102A1140202059A 02013B300B30090A01050A01030A0104
Sep 28 18:09:48.114: Facility i = 0x91AA068001008201008B0100A1160202059B 06042B0C0900800A464F544F475241464F53
Sep 28 18:09:48.126: Calling Party Number i = 0x0080, '4043', Plan:Unkno wn, Type:Unknown
Sep 28 18:09:48.130: Called Party Number i = 0x80, '8899', Plan:Unknown, Type:Unknown
Sep 28 18:09:48.134: High Layer Compat i = 0x9181
Sep 28 18:09:48.138: Locking Shift to Codeset 5
Sep 28 18:09:48.138: Codeset 5 IE 0x31 i = 0x80
Sep 28 18:09:48.138: Codeset 5 IE 0x32 i = 0x81
2651XM-Informatica#undebug all
Regards.
Hi this is what I get ...Where is the problem?
*Sep 28 17:18:32.523: ISDN Se0/0/0:15 EVENT: process_pri_call: call id 0x8075, n
umber 73345, Guid Se0/0/0:15, speed 0, call type VOICE, redial No, CSM call No,
pdata Yes
*Sep 28 17:18:32.523: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x16 i
s 0x0 0x0, Calling num 72775
s 0x0 0x0, Called num 73345
*Sep 28 17:18:32.523: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0075
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '72775'
Called Party Number i = 0x80, '73345'
*Sep 28 17:18:32.563: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x8075
Cause i = 0x80D2 - Identified channel does not exist
*Sep 28 17:18:32.563: ISDN Se0/0/0:15 EVENT: process_rxstate: ces/callid 1/0x807
5 calltype 2 CALL_REJECTION
5 calltype 2 CALL_CLEARED
Thanks for your help!
Can you please add the following configuration to the E1 controller and post the debug result again ?
isdn bchan-number-order ascending
Also, is the E1 line on the PBX side configured to accept connections on all of the timeslots (1-31) ?
Regards..
660
