outside call forwarding
rvincent
user wants to call forward his IP phone to his cell phone. Sets up the all call fwd feature to dial out to his cell. when a outside caller dials his phone, call does not go through, caller hears silence.
the call is a DID call & comes in via a vg200 e/w MFT-T1 card. Outgoing calls are made via the same MFT-T1. if i call user phone from inside the system, call goes to his cell phone. is there something in the gateway that is preventing this from working or is it in the call manager?
thanks
Rob
tim.medley
Level 2
Level 2
Can you post or forward your config? What you dsecribe should work. We mostly use cisco 2621's as H323 gateways, we have a bug where calls forwarded back out to the PSTN have no ringback tone.
tim
Tim Medley, CCNP+Voice
Network Architect
VoIP Group
iReadyWorld
dgoodwin
On the VG200, can you try setting voice rtp send-recv in the global config? Also, what version of IOS are you running on the VG200, and can you paste the config?
Dave:
I tried the voice rtp send-recv command - no change.
Here is the config I'm using on the vg200:
no ip dhcp-client network-discovery
call rsvp-sync
voice rtp send-recv
controller T1 1/0
framing sf
linecode ami
cablelength short 133
ds0-group 1 timeslots 1-10 type e&m-wink-start
ds0-group 2 timeslots 11-14 type e&m-wink-start
ds0-group 3 timeslots 15-24 type e&m-wink-start
interface FastEthernet0/0
ip address 10.1.75.4 255.255.0.0
speed 100
full-duplex
ip default-gateway 10.1.50.2
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
voice-port 1/0:1
voice-port 1/0:2
voice-port 1/0:3
echo-cancel coverage 16
dial-peer voice 11 voip
destination-pattern 52..
session target ipv4:10.1.75.7
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
no vad
dial-peer voice 10 voip
preference 1
session target ipv4:10.1.75.2
codec g711ulaw
no vad
dial-peer voice 1 pots
direct-inward-dial
port 1/0:1
dial-peer voice 2 pots
application second_did_grp
direct-inward-dial
port 1/0:2
dial-peer voice 91 pots
application first_outgoing_grp
destination-pattern 9.......
port 1/0:3
dial-peer voice 92 pots
preference 1
application second_outgoing_grp
port 1/0:2
Rob
lee.wheeler
I am having similar reports from our users. Our system uses a 2621 w/ NM-HDV-2T1-48 using one T1 as the PSTN gateway.
