Community Member
Outside caller do not hear transfer rings.
When a person calls in from the outside and dials a person’s extension the caller hears is dead air. They do not hear the person’s phone ringing. Some callers hang up and think they have been disconnected.<br><br>I have it set to transfer the call back to Call Manager.<br><br><br>
Anonymous
N/A
Re: Outside caller do not hear transfer rings.
This was a known issue with CallManager and certain versions of IOS. It doesn't have anything to do with Unity, the same thing should happen if an outside caller is transferred by an IP phone. Please provide the version number of CallManager and the GW, and I'll see if I can get one of the CM TAC specialists to chime in.
Steve Olivier
Software Engineer
Cisco Systems
Community Member
This problem is fixed in CM 3.0(10) AND IOS 12.2(3). You need to upgrade your CM and your gateway.
-Dustin
Anonymous
N/A
Do you have the bugIDs for this? I need to fix
it ASAP as well.
Community Member
Bug ID for IOS side is CSCds87266
Bug ID for CM side is CSCds11354
-Dustin
Gold
I know everybody calls this a bug but really it is not. The H.323 spec does not provision for ring back after the call is connected. It was changed as a 'feature enhancement' not a bug.
Anyway, check out this URL too:
http://www.cisco.com/warp/public/788/voip/ringback.html#unity
Keith
Keith Chambers
Unity Technical Lead
Unified Voice Team, San Jose
Cisco Systems
kechambe@cisco.com
126
