Outside calls not being forwarded to Unity voice mail
Hi there,
I have a Unity UM integrated with CCM. I have configured CCM such that if the phone was not answered on a certain number of rings, it will be forwarded to the voice mail. Internally, local to local, the calls are forwarded to Unity with no problems. But when an outside call initiated the call, it returns a busy tone instead of the Unity voicemail system.
Hoping you've got some answers... thanks
Roy
Re: Outside calls not being forwarded to Unity voice mail
Hi Roy,
Are your Unity Voicemail ports in a partition that is in the CSS allocated to the Gateway for inbound calls? Sounds like it could be a gateway CSS issue.
Bill.
Hi Bill,
We have not defined a partition on the Voicemail ports. Do we have to create them? We can access them via local (ip phone to ip phone).
Roy
Bill,
We have a pilot number for voicemail setup as 1201 (16 ports). This is in hunting group.
Accessing this via the local phones, it responds. But when accessing it on outside lines, it returns a busy tone. We have an auto-attendant setup to manage incoming calls, wherein I can dial the extension number of the person that i'm looking for. Can I dial 1201 from there? I tried dialling it from there and it returns that the said number is out of service.
Help is very much appreciated.
Roy
Silver
Set the CallManager service parameter "Disable Alerting Progress Indicator" to True.
Check, if that helps here !!
This was defaulted to False. We changed it to True, but the problem still exist. Do we have to reboot the CCM?
Roy
154
