Packets Larger Than Fragmentation Size Get Dropped in FR
Hello, if anyone can help me with this issue, then i would greately appreciate it.
I have 3 offices with FR links through my ISP MPLS networks. The central office has 1536 kbps link and the other 2 remote offices each has a 512 kbps link.
I am doing VoIP over the FR links with policy-based fragmentation on the subinterface. I configured the fragmentation size to be 640 bytes (the recommended size for 512 link) for each FR link. The central office also has the fragmentation size of 640 bytes even though it has a 1536 kbps link because i needed to keep the fragmentations size consistent with all my FR links.
The problem is when sending packets that are larger than the fragmentation size (>640 bytes), the packets get dropped. When i removed the fragmentation configuration, then everything works fine.
Does anyone have any idea how i can configure fragmentation correctly on FR links? Any help is appreciated. Thanks.
JD
Here is a partial sample of my config.
class-map match-all VoIP_Traffic
match access-group name Voice_Traffic
class-map match-all VoIP_Signalling
match access-group name Voice_Signalling
policy-map VoIP_Priority
class VoIP_Signalling
bandwidth 8
class VoIP_Traffic
priority 500
class class-default
fair-queue
random-detect dscp-based
interface Serial0/0/0
description <<Link to NVPN Networks>>
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
no fair-queue
service-module t1 timeslots 1-8
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description <<Point-to-Point FR>>
bandwidth 512
ip address 10.10.10.1 255.255.255.252
frame-relay interface-dlci 123
class VOIPovFR
map-class frame-relay VOIPovFR
frame-relay fragment 640
frame-relay cir 512000
frame-relay bc 5120
frame-relay be 0
frame-relay mincir 512000
service-policy output VoIP_Priority
1 REPLY
Bronze
Re: Packets Larger Than Fragmentation Size Get Dropped in FR
91
