12-17-2002 08:34 AM - edited 03-12-2019 09:59 PM
Unity 3.15 CCM 3.2.2
Attempting to set up pager notification. Haveing a few problems:
1: Can't tell if Unity is ACTUALLY calling out. status monitor shows that the port initializes, dials 9,1201XXXXXXX - stays active for about 15 - 20 seconds, and then closes the connection. Not sure if the " EXTRA DIGITS" are being dialed. No errors are being logged in the event viewer. Call manager Trase logs are showing a call being made.
QUESTION1: Is there a way to hear, tell, what is actually being done?
Our call manager is connected to a EON Milennium via T-1 from the VG200 to Milennium. All calls from CCM are being routed to the millenium, and then out that gateway to the PSTN. Calls can be transferred from an IP set to a milennium set
ie: call from IPSET-A to IPSET-B. Call is then transferred from IPSET-A to
Milennium Set. That transfer completes successfully.
From within Unity: attempt to dial the extension on the same milennium set, the transfer test was just conducted on. Unity does not understand the request. MILLENIUM SETS WILL NOT BE USING UNITY AS VM BOX.
QUESTION 2:
Does a dual integration have to be configured if Unity will be routing thru the VG200 to the Milennium, regardless of the fact that no one on the EON side will be using Unity? We are only using the milennium to get a PRI and access the PSTN.
Hope I was clear enough in my description.
12-17-2002 08:52 AM
For question 1, you could open up Unity traces, but it might be easier to troubleshoot it this way (start simple and then get progessively more complicated).
1. Instead of starting out at pager notification, just try regular notification (where Unity just calls a phone). Start with notificaiton to a phone on CCM and get that working. This will make sure that the general configuration for Unity dial-outs is working.
2. Then start with notification to a phone on the Millennium. This will make sure that the call routing is set up correctly on CCM and the Millenium.
3. Once the previous step is working, do notification to a phone that will traverse the PSTN connectivity off of the Milennium (some outside line).
4. Then do a "fake" pager notification to that outside line. Set it up so that it will dial similar extra digits that the "real" pager dial-out would. This will ensure that the DTMF digits are really being passed after the call is connected to the the pager service.
For question 2, if Unity's use of the Millenium is to only get to the outside world, there's no need for dual-switch.
12-17-2002 09:48 AM
>>>> done & working.
>>>> this one is ok too.
>>>> working.
We tried this: should the "Fake" pager hear tones when they pickup? If so, they do not, so i can only assume that DTMF is not being forwarded. If NOT, then what SHOULD happen?
12-17-2002 10:06 AM
Try calling the "fake" pager directly from an IP phone. Once the call is connected try some DTMF key presses and verify that they are correctly being relayed as tones to the outside line. If not, they're probably being dropped at one of the gatways.
12-17-2002 10:20 AM
they are being relayed... when I dial them,
when unity calls a number, and tries to dial the numbers in the " Extra Digits " field, nothing happens, and the call disconnects after a few seconds. Below is the Notification Setup
Phone Number
9,1201xxxxxxx
Extra Digits
12345678 <<<<<<<<<<<<<<<< ( should these be audible ?)
Dialing Options
checked Try to detect connection
checked Seconds to wait before dialing extra digits " 2 "
12-17-2002 10:38 AM
Yes, those should sound exactly the same as when you dialed them from an IP phone. When you call from an IP phone, how long do you wait between dialing the last digit of the phone number and the first of the extra digits?
The "Try to detect connection" isn't always effective when dialing out a gateway. Unity may be receiving "connected" as soon as the first leg of the call is established. In that case, Unity might dial all of your extra digits before the call is even answered. Try bumping up the "Seconds to wait before dialing extra digits" to match what you were doing on the IP phone.
12-17-2002 11:07 AM
disabled " try to detect connection "
retried the fake pager
number dialed, phone rings, i pick up and get silence. call disco's after few seconds. None of the " Extra Digits " are dialed. The ammount of time that the call stays active is = to the time alotted in the " Seconds to wait before dialing extra digits. "
Fake Pager is not an IP phone, but a milenium set.
Does something have to be modified in the restriction table to get this to work?
PS: thank's for all the assistance. i'd like to see if i can get this resolved w/o calling TAC.
matt
12-18-2002 06:30 AM
still stumped... any ideas where to go from here
12-18-2002 08:54 AM
I am also out of ideas for easy things to check. From here you could start looking at Call Manager traces. Compare a pager notification call from Unity with your test call from an IP phone (are you using a Skinny phone, like a 7960?). The dialing of "extra digits" should show up the same in both. If this is the case then you should next look into the VG200 gateway. Otherwise, if the extra digits from Unity are not showing up on the Call Manager trace, then you should next look into Unity diagnostics (are the extra digits audiable if you send the call to another IP phone?). In either case, TAC may be able to speed things along for you.
12-18-2002 08:50 AM
It's not a restriction table issue. Place an IP phone in the same CSS as the Unity port that's set to do pager dialouts. Call the same phone that you have set up for the pager dial-out. Answer that phone and from the IP phone, dial digits. Can you hear them on the other phone?
12-18-2002 09:19 AM
yes you can.
12-18-2002 02:55 PM
It's probably time for traces. Whether Unity is dialing the digits to fast for the GW, not dialing them, or dialing then and they're not getting relayed to the GW is what those traces will help find out. If TSP traces are enabled, and you explain what number is being dialed, along with the follow-along digits, we can tell of Unity is dialing or not. Beyond that, it might be time for a TAC call.
12-18-2002 05:36 PM
good deal. will set up some traces, and see what pops up. will a tac case as well and get them on it too.
thanks guys
Matt
12-17-2002 10:11 AM
Regarding your attempted transfers...
When you dial the extension of the Millennium set, the Unity auto-attendant will need to match this to a subscriber or call handler. That subscriber or call handler can then be configured to perform the transfer.
