Paging Feature in IP Telephony
Any body knows if in Call Manager exists at feature name "Paging". This feature allows you to make a voice announcement from the speakers of the proprietary telephones.
Re: Paging Feature in IP Telephony
Check out InformaCast by Berbee..
CCM only has set-to-set native paging, using the autoanswer feature.
http://phone-xml.berbee.com/
I have tried the demo of Informacast, and have had some trouble gettng it to work, but I didn't devote a lot of time to it. It seems to do quite a good job from what I've heard.
If you want to do conventional paging, you can tap into a speaker system with an amp and a paging module via an analog port from an ATA. We use this at many sites since they already had the speaker system for paging intact. Just another option.
215
