Password and PIN sync
Is there a way to sync and unify the passwords and PINs between Unity Connection, CM5.1, and Meetingplace Express 1.2
Andy
1 REPLY
Bronze
Re: Password and PIN sync
Try using LDAP directory service.
To use only the Cisco Unified CallManager database for users, which is the default functionality when you install Cisco Unified CallManager, Release 5.0, create users with End User Configuration to add to the database (password, names, device association, and so forth). Authentication takes place against the information that is configured in Cisco Unified CallManager Administration. End users and administrators can make password changes if this method is used. This method does not entail LDAP synchronization.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00806b0386.html#wp1068959
152
