09-07-2006 07:37 PM - edited 03-13-2019 02:54 PM
Does anyone know how to put a puase character in a speeddial or fastdial?
I need a pause after I dial the phone number.
cm version 4.1.3
09-07-2006 08:09 PM
Not possible,
We have a DDTS for that.
Pauses are available in DP pots using commas.
09-07-2006 08:15 PM
Normally we redirect you to your AM to fill a PER request to get this feature include in
furure releases. A PER has been already been filed but not included in any CCM version
You may check AutoDialer sample application which is included in the IP Phone Services SDK version 3.3.
A user subscribes to the service and supplies a string of digits which can include commas - each comma is a 1-second pause. I personally use it for calling-card dialing. Dialing is performed by PUSHing Key:KeyPadx URI's to the phone with
appropriate pauses in between.
10-11-2006 01:57 PM
Does this limitation also apply to Fast Dial? And if so has a PER been filed for this?
10-11-2006 03:50 PM
I have tried a couple different ways... and the only way someone told me to get this to work is to use the SDK pack... which I said forget it.... I tried the XML dialer... it did work for voicemail.. I could have it enter in my password for me with some commas.. but Conference calls, no luck.
http://www.voip-tools.org/index.php?option=com_content&task=view&id=56&Itemid=85
If you find something, post it up...
