01-16-2002 06:30 AM - edited 03-12-2019 02:03 PM
I have users on a PBX system connected to a T-1 tie line. When PBX users call an extension and the extension forwards to Unity, the calls are dropped. If Calls are made from within the system or from the PSTN, the calls get transferred to Unity. PBX calls complete when a user answers the phone or if the calls are transferred to another extension and that user answers the call.<br><br>
01-17-2002 04:20 AM
What kind of PBX is this? What type of voice boards are in Unity? Can you call Unity directly from an internal phone? from the PSTN? Can Unity make outbound calls (i.e. message notification)?
-Eric
01-17-2002 04:20 AM
I am going from a G3 switch to an H.323 Cisco router gateway, accross a T-1 to another H.323 Gateway to a Cisco CallManager version 3.1(2)c to the Unity version 3.02. All calls to these phones from anywhere will go to voice mail except the call originating from the PBX.
Tom
01-18-2002 09:44 AM
Ah, that makes it interesting. I'd wager the calls are being dropped before they even reach Unity.
What signalling is on the T1? CAS? QSIG? ?
Can PBX users call directly into Unity?
Place an IP phone in the same Calling Search Space as Unity. Can PBX users call this phone directly? Can PBX users be forwarded to this phone?
01-18-2002 10:27 AM
Check your CODECS all the way through. It might not hurt to install the G.729 CODEC on your Unity box and see if the problem goes away.
--Cael
01-24-2002 06:44 AM
That was it! The gateway had to be changed to g.711.
Thanks for the Info
