PBX performs tandem swithching between VoIP and VoFR
I've got the following configuration:
SCENARIO
1751V=voip=2600 A=vofr=2600 B
Note: we have PBX connected to 2600 A and B routers through two E&M ports.
LIMITATIONS
Regargind our service provider we can not apply cRTP on frame-relay pvc, cause we have "encapsulation frame-relay IEFT". In that case we apply VoFR that works fine.
Separately VoIP is applied on leased line between 1751V and 2600 A.
POSSIBLE SOLUTION
PBX tandem switching could be a solution that way:
1751V=voip=2600 A [2 ports e&m PBX A connected]=voip=2600 B= [PBX B]=PBX phones.
THE PROBLEM
At this moment we must perform calls between 1751 fxs phone and 2600 B pbx phones.
CONFIGURATIONs
!--Router A (voip)
dial-peer voice 30 pots
destination-pattern 30
port 2/0
dial-peer voice 999 voip
destination-pattern 1511.
session target serial0/0 20
dial-peer voice 20 voip
destination-pattern 2.
session target ipv4:192.168.93.187
!--End router A.
!--Router B (connected to voip/vofr tandem switching PBX)
dial-peer voice 30 voip
destination-pattern 3.
session target ipv4:192.168.93.186
dial-peer voice 20 vofr
destination-pattern 1.
session target Serial0/0 20
dial-peer voice 51 pots
port 1/0/0
prefix ,511
dial-peer voice 99 pots
port 1/0/1
prefix ,2
!--End router tandem.
!--Router B (vofr)
dial-peer voice 20 pots
port 1/0/0
prefix ,,1
dial-peer voice 10 vofr
!--End router B.
NOTES
Extensions:
ROUTER A = 30
PBX TANDEM = 1X
REMOTE PBX = 2X
"51" is the e&m trunk access digit from PBX.
At this moment calls from 1751 through 2600 B do not arrive. Calls get in PBX (connected to 2600 A router) and use the two e&m pbx ports, but the call did not switch to VoFR and do not arrive to remote PBX B.
RESOURCES
I've founded information regarding router tandem swithching, but I need information about pbx tandem switching VoIP/VoFr calls.
Does anybody been involved in a similar case? CCO only provides configuration examples about router tandem switching configuration.
I have opened a TAC case but no useful information is answered.
Thanks and regards
131
