02-05-2006 08:37 PM - edited 03-13-2019 12:04 PM
Does any body know what this Enterprise Service parameter mean ?
Peer Mode Enable Code - This parameter specifies the code to enable Peer Mode Database. Default 0000, Maximum length : 4
TIA
Sankar.
02-06-2006 08:44 PM
Anybody ??
02-10-2006 01:11 PM
Snoooze.....
PS: I can see this parameter.only in CM 3.3.3
It seems to have disappeared in CM 4x
02-10-2006 04:13 PM
Hi Thisishanky,
don't use this parameters. It has no impact to any supported functionality.
PS.: you can find it in CCM 3.3(4) too.
02-10-2006 04:57 PM
Thanks for your input. All I am trying to do is try to understand various service parameters. I am only changing this on a lab server. So it should be ok, if something goes wrong.
Still looking to find out what it exactly means and if it doesnt have an effect, why is it even there.
