08-25-2003 07:24 AM - edited 03-13-2019 01:19 AM
Hi all,
I´ve got a problem in a test-environment using Callmanager 3.3.2spc and Personal Assistant 1.3(4). After installation of PA I´ve already installed the new JTapi-Client from the Plugins-Page of Callmanager on the server where PA is running. But still I get the following error in event-viewer:
Error: kCtiIncompatibleProtocolVersion - Incompatible protocol version.
Message Version: 30000
Minimum Version: 40000
Current Version: 40000
CallManager Version:
QBE Client Version:
IPAddress: 192.168.112.13
App ID: Cisco CTIManager
Cluster ID: StandAloneCluster
Node ID: 192.168.112.3
Process ID: 968
Process Name: CtiHandler
Explanation: The JTAPI/TAPI application version is not compatible with this version of CTIManager, so received message has been rejected.
Recommended Action: Verify correct version of application are being used; otherwise, contact TAC..
What can I do. Thank you for your ideas.
Markus
08-28-2003 01:02 AM
First uninstall Cisco JTAPI from the Add/Remove Programs in your Win2k ctrl panel.
Then browse to CCMAdmin from the PA box. Go to Applications drop down and select Install Plugins.
Select Cisco JTAPI and "run from this location" Reboot and you should be good to go.
G'luck,
James
08-28-2003 01:09 AM
Hi James,
I did that allready!!! That did not solve the problem. But I´ve found a solution: There is a PA-ccm33.bat file on the machine that has to executed after the installation. Soon the ports all came up! But thank you for your idea.
Best regards,
Markus Thelen
