Personal Assistant not routing all internal calls
Hi All,
I've got users who are using Personal Assistant to route internal calls separate from external.
It doesn't seem to pickup internal users properly though. If a user is in the Corporate Directory it works fine but users on the PBX system and base non-logged-in Extension Mobility phones route as External!!! Is this a bug or is there another way of specifying internal phones?
Stuart
1 REPLY
Silver
Re: Personal Assistant not routing all internal calls
The problem is due to the issues with MWI for IPMA Manager and divert with IPMA Console. Select as service 'Cisco IP Manager Assistant' For each server, set the trace level to "Detailed" and check all the traces and flags.
111
