Community Member
Phone Firmware Load Change
I have a couple of 7941/61 phones I need to load 8.04sr1 on. I downloaded the zip file and unzipped and now have 5 .sbn files and 3 .loads files.
Do I copy all of them to the TFTPPath directory of each Call Manager including the term41.default.loads and term61.default.loads files? I do not want to change my default firmware loads at this time.
Thanks!
1 REPLY
Hall of Fame Super Silver
Re: Phone Firmware Load Change
You need to copy them to all TFTP servers. In order for the phones to use the new files you will need to change the device defaults under System in CCM or at the device level. To test it out on only some phones apply the new name at the device instead of the global default.
Chris
141
