Community Member
Phone IP for CCM 5
I am trying to find out how to get device IP for call manager 5. I know how to do it with 4, but it is not working for 5. Does anyone know how?
1 ACCEPTED SOLUTION
Re: Phone IP for CCM 5
Did you get the appropriate IP Phone services developer guide for your ccm version? It tells you that devicelistx.asp is out with CCM5.. you now can get it via SNMP or via AXL serviceability (the SelectCmDevices command).
You can find the guide here: http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
And if you enter SelectCmDevices in the forum search engine you'll find a few threads with working examples.
Also note that SelectCmDevices only returns 200 devices.. so you'll have to send an sql query to the callmanager using AXL to get the full list, then make one SelectCmDevices query per 200 phones (annoying I know but that's the way it is).
Community Member
I saw an answer from stephan.steiner - Aug 14, 2008, 12:23am PST, I will try it. Sorry to bother with new question on answered task.
Greetings
Community Member
Hi stephan,
thank you for the answer, I will write some working example to try it asap. Once again thanks.
113
