Phone Is Ringing, But Calls Are Not Being Completed
We have a private branch exchange (PBX) connected to an AS5300 universal access server that initiates a call to a PBX connected to a Cisco 3640. The phone rings, but there is only a brief squeal and then nothing. The calls coming from the other way are fine. The following is the path the call takes:
<p>
pbx-5300-7200-FR-3640-pbx
<p>Why are my calls not being completed?
1 REPLY
Anonymous
N/A
Re: Phone Is Ringing, But Calls Are Not Being Completed
If the phone rings then I would suppose signalling
is fine hence ip routing is enabled on
both originating and terminating gateways.
However if no proper QOS is enabled for voice within
your network , then its quite possible that the voice call will
fail as its not at all tolerant to end-to-end delay greater than 150ms.
1. Check you round trip delay for a ping packet
2.do a few "sh call active voice" command and compare the transmit and receive
rtp streams to see if you're sending voice pakets
and receiving.
3. check you QOS config
97
