Community Member
Phones pull IP from Data DHCP
Hello all -
I'm having a problem that seems to be getting worse. I have 350 or so 7910/40/60 phones running on CCM 3.2 (1 pub, 1 sub, 1 unity) in a small office environment. When phones are restarted for whatever reason (switch matintenence, etc), some of the phones register with the DHCP server on the data VLAN vs. the Voice DHCP scope located on publisher. This prevents the phone from contacting the correct TFTP server and registering with the call managers.
I have seperate voice and data VLAN's configured and a DHCP server on each for IP's. No helper addresses are configured on the voice network, so I can't see why the phones are jumping over the the data vlan and dhcp server.
Any ideas?
Jad
2 ACCEPTED SOLUTIONS
Community Member
Re: Phones pull IP from Data DHCP
We had the same issue, it was a problem with the firmware load for the phone. Either put option 150 on the data VLAN or upgrade the phone load. Hope it helps (assuming it's the same issue).
Community Member
I had the same issue as well. To resolve it, I had to put the switchport access vlan on the phone vlan, let the phone boot once and upgrade its firmware. I was then able to put the access vlan back to the data vlan.
Let me know if this works for you.
Super Bronze
What kind of switches are you running?
Can you post the config of a switch that exhibits this problem?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Aaron - thanks for the quick response. Unfortunately i can't post the full config due to our security regulations. I'm using various switch models on each floor, but the most recent problem involves a 3560:
(C3560-I9-M), Version 12.1(19)EA1d, RELEASE SOFTWARE (fc1).
Let me know if you're looking for something specific.
Jad
Community Member
We are experiencing this same problem. Our switches are POE 3750's running 122-25.SEE1.
Community Member
Community Member
Community Member
Thanks guys - i updated the loads for all 7940's and 7960's to P00308000200, rebooted, and all went well.
178
作成コンテンツを作成するには してください
