Community Member
PickUP group with IP Phone and Softphone
is it possible to create a Call PickUp Group with Softphones and IP Phones together ??
Martin
Community Member
Re: PickUP group with IP Phone and Softphone
Yes, this should work as only DNs and the partition info is allocated to the Call Pickup Group. Did you try it out? Does it work
Community Member
The only down fall to this is that you cannot pickup a call that is ringing on the 7960 from the Softphone Application. There is no facility for that.
That is the only problem I see.
123
