Pilot Point Busy Tone
Hi, I have just upgraded CallManager 3.2.3 to 3.3.3sr4. There are about 1200 devices, everything works except for one critical thing. All our pilot numbers are busy tone. The only apparent error message I get is the following message in Event viewer on the subscriber.
Error: kCtiProviderOpenFailure - CTI application failed to open provider
CTIconnectionId: 89
Login User Id: ac
UNKNOWN_PARAMNAME:ReasonCode: 2362179680
IPAddress: 10.10.101.2
App ID: Cisco CTIManager
Cluster ID: LBB-CM1-Cluster
Node ID: 10.10.101.2
Explanation: Application is unable to open provider.
Recommended Action: Check the reason code and correct the problem. Restart CTIManager if problem persists..
It looks as if it's trying to use an AC UserID which we haven't got as we're not using Attendant Console. I have also tried removing all CSS and partitions in case that was issue.
Any help would be greatly appreciated,
Daniel
Re: Pilot Point Busy Tone
Daniel,
For Pilot Points to work you still need the "ac" user configured in the Global address book and you will need to associate the pilot points with the AC user.
Hope this helps
Glen
Hi Glen, thanks for getting back to me.
I tried that earlier, I created the ac userid and associated all the pilot point numbers with it. Still didn't work though.
Daniel
All sorted. Had to restart the despatcher service on publisher and subscriber.
119
