Plar problem with SRST IOS
I discovered a problem with IOS 12.1(5)YD2. Incoming calls on my T1 PRI will not forward to the destination specified on my Plar statement on the T1 Voice-Port. I tried IOS 12.1(5)XM4 with the same configuration and it works with no problems. I also tested incoming calls on the POTS lines with IOS 12.1(5)YD2 and this worked curreclty with my plar statement on the FXO voice-port. Is there another way to forward all incoming calls from my T1 PRI to a specific extension?
-Ken
Re: Plar problem with SRST IOS
I don't believe that PRI is supported is SRST yet, not until YD3.
I was informed the specific function of SRST wasn't supported but the IOS should still work and allow me to use my POTS lines for the SRST option.
any idea when yd3 is going to be available?
132
