PLase Help with GK
Hi...I am new in this of Cisco Gk .
I have a Cisco 2600, an ATA186 and a Cisco AS5300.
I would like to make a test and I could not make it work. I would like to register my ATA to the GK, but not my AS5300. Then I would like to make a call from My ATA to the AS5300. How could I configre the GK to register my AS5300 as an tatic route (I am using the alias static command but is nor workin) My ATA is registring correctly to my GK (at least I think because it appears this in the GK
CallSignalAddr Port RASSignalAddr Port Zone Name Type F
xxx.xxx.xxx.xxx 1720 xxx.xxx.xxx.xxx 1719 GKt TERM
H323-ID: xxxxx
E164-ID: xxxxx
And the AS5300 appears also registered as static with the e164 ( I omit the number using x) xxxx.......
When I dial xxxx....... in my ata It does not connect to the as5300 (even though the as5300 has correctly configured the peer ) (becuase if I call direclty from the ATA to the gateway without GK it works)
PLease somebody help me with this
REgards.
1 REPLY
Re: PLase Help with GK
Check out the TAC GK & ATA docs in the H.323 TAC Support Page:
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Internetworking:H323&viewall=true
There are 4 docs that will help you get started to configure your GK.
- Carlos
84
