Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Please help: CTI-RP wont register!!!!!
Im having an issue with a new CTI-RP.
I have CCM4.0 , IPCC Enterprise 6.0.
I did the following:
- created a new Route Point (with the same config as other existing CTI-RP)
- added a directory number.
- associated the CTI-RP with the JTAPI user.
But it still shows Registration:unknown.
On ICM side i already configured the dialed number/associated Calltype, script.
I did the following to fix it but nothing helped:
1- deleted and recreated the CTI-RP
2 Dialed the CTI-RP DN and checked "router log viewer" on ICM but it didnt show anything, so the problem is on Callmanager side.
Can someone help????
Hall of Fame Super Silver
Re: Please help: CTI-RP wont register!!!!!
Is this the only CTI-RP that does not work or is it the onyl one in the system?
Chris
this is the new one that doesnt work, all other CTI-RP works fine.
The troubleshooting steps are fine but perhaps not in the correct order, try the following (in the exact order):
1.- Delete the CTI RP in CCM.
2.- Delete the JTAPI trigger in the CRA.
3.- Create a new CTI TP in CCM
4.- Create a new JTAPI trigger in the CRA.
5.- Associate the CTI RP with the JTAPI user.
6.- Restart the CTI Manager service in CCM
7.- Restart the engine in the CRA.
Let me know if that helps
//Jorge
Tank you for your replys.
@jbarcena
Why are you referring to the JTAPI trigger in CRA??? i thought this is just for IVR-PIM connection.
The CTI-RP that im using is associated with the JTAPI user in the PG (Callmanager PIM).
@gajolly
I didnt find anything in the Application log. In the SDL traces i just find (Block NoPotentialMatchesExist) after dialing the CTI-RP.
Hi Jay,
Can you please check the application logs n let me know if u r getting ny error messages or warnings regarding CTI Route point u r creating...
@jbarcena
@gajolly
I made a forward all from that CTI-RP number to another extention of an IP-Phone, when i dialed the CTI-RP it rings on that IP-Phone. why it still Registration:unknown
Got it working, just restarted the CTI Callmanager!
Thanks all.
191
