Please help with COR config question on CME
Gurus,
I have been struggling for some time to now to get COR set up properly on my CME. I did have a breakthrough when I discovered that INCOMING and OUTGOING meant from the viewpoint of the router, NOT the phone. Still I am having issues, specifically with the Dial-peer config. I find examples ranging from elaborate to simple, and don't know which to use.
I only wish to block on some instruments Long Distance (my area code is 907), international, 411,1900, and 555-1212. Please see my existing config below; could someone tell me how to configure the dial-peer portions? I get my dial tone from a PRI T1, if it makes any difference, and we dial 9 first.
Michael
dial-peer cor custom
name 911
name 1800
name local-call
name ld-call
name 411
name int-call
name 1900
dial-peer cor list call1800
member 1800
dial-peer cor list call911
member 911
dial-peer cor list callint
member int-call
dial-peer cor list callld
member ld-call
dial-peer cor list call411
member 411
dial-peer cor list localonly
member 911
member 1800
member local-call
dial-peer cor list call1900
member 1900
dial-peer cor list LongDistance
member 911
member 1800
member local-call
member ld-call
dial-peer cor list calllocal
member local-call
Re: Please help with COR config question on CME
apply
call1800, call911, callint, callld, call411 , calllocal COR lists in the outbound direction on respective dial-peers.
for ex:
dial-peer voice 1 pots
destination-pattern 911
no digit-strip
corlist outgoing call911
port 1/0:23
dial-peer voice 2 pots
destination-pattern 91800.......
forward-digits 11
corlist outgoing call1800
port 1/0:23
dial-peer voice 3 pots
destination-pattern 9[2-9]......
forward-digits 7
corlist outgoing calllocal
port 1/0:23
so on and so forth.
The following cor lists localonly, LongDistance etc, apply to phones as required.
ephone-dn 1
corlist incoming localonly.
So ephone-dn 1 will have access to 911, 1800 and local-calls as the corlist applied on the phone is a superset of the corlist specified on the respective dial-peers for 911, 1800 and local-calls.
Sankar
PS: please remember to rate posts!
Thanks for the help!!
I've applied your config, then applied the COR to my own personal phone. I tried to dial a 9-1-903-xxx-xxxx (Texas somewhere...) and was able to do so. The COR settings should have prevented this??
This is my current config, as it applies to COR:
voice-port 0/0/0:23
name 911
name 1800
name local-call
name ld-call
name 411
name int-call
name 1900
member 1800
member 911
member int-call
member ld-call
member 411
member 911
member 1800
member local-call
member 1900
member 911
member 1800
member local-call
member ld-call
member local-call
dial-peer voice 20 pots
no digit-strip
port 0/0/0:23
dial-peer voice 21 pots
port 0/0/0:23
forward-digits 11
dial-peer voice 22 pots
port 0/0/0:23
forward-digits 7
ephone-dn 4 dual-line
number 3809
label Mike 3809
description Michael Albert
name Michael Albert
call-forward busy 3801
call-forward noan 3801 timeout 15
corlist outgoing localonly
Thanks again for your help,
Michael
Hi Mike,
I don't see your dial-peer for Long distance.
Try something like:
dial-peer voice 23 pots
corlist outgoing callld
destination-pattern 91..........
port 0/0/0:23
forward-digits 11
You will probably also need a similar dial-peer for International:
dial-peer voice 24 pots
corlist outgoing callint
destination-pattern 9011.T
port 0/0/0:23
prefix 011
Also, you need to apply the corlist for your phone in incoming direction:
number 3809
label Mike 3809
name Michael Albert
Hope this helps,
Val
Val is right.
You are missing a dial-peer for long distance.
This is my current config:
name 911
name 1800
name local-call
name ld-call
name 411
name int-call
name 1900
member 1800
member 911
member int-call
member ld-call
member 411
member 911
member 1800
member local-call
member 1900
member 911
member 1800
member local-call
member ld-call
member local-call
no digit-strip
port 0/0/0:23
port 0/0/0:23
forward-digits 11
port 0/0/0:23
forward-digits 7
port 0/0/0:23
forward-digits 11
port 0/0/0:23
prefix 011
number 3809
label Mike 3809
name Michael Albert
Still I am able to dial a long-distance number (9-1-903-xxx-xxxx). Does this config look good to you?
Michael
Are you sure you are matching only dial-peer 23 with this number.
How did you dial the Texas number before adding the LD dial peer?
Do you have other PSTN trinks on this router?
Please paste the whole config for the router.
V.
I was hoping you'd ask that. I wondered if I had something else going on that was screwing things up.
Thanks for the time!
Greetings,
The config looks OK in the COR piece.
I don't see an obvious reason for your issues.
Try "debug voip ccapi inout" and make sure that the called LD number matches dial-peer 24. There are potentially few matches with dial-peer 24 being the longest one but just in case try to verify this.
Also try "debug ephone detail".
If you could afford it you can try to reload the router with just basic config and COR, no translation rules and other dial-peers for incoming numbers, and give it a try again.
You can also try another phone with "corlist incoming calllocal" and you shouldn't be able to call 1800 as well.
Good luck!
Val.
184
