aod
Community Member
POE and AC
What happens if I inadvertently plug in an IP Phone into a POE port that is already plugged into an outlet?
Bronze
Re: POE and AC
I accidently done it b4, nothing happen to my phone
Silver
Re: POE and AC
If you use both PoE and the outlet, then the power source from which the IP Phone first got the power becomes the primary power source and the second one is used as a backup.
In your case, the phone will continue to use the outlet power and if it loses the power from the outlet at some point, then would switchover to PoE.
Anup
119
