Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
point to point voice issue
Dear all,
i'm new to voice pls help me.
i have connected 2 offices using a p-t-p 128kbps leased line.routers are 2801.i have checked the connectivity
its fine.i'm using wic-1T for this connectivity on both sides. for voice purpose i have installed VIC2-FXS card.
my IOS on both sides are "c2801-ipvoice-mz.124-6.T2.bin".
and i have installed PVDM2-8 is installed on both routers.
my plan is to put 2 phones at each office.my phone is Ericsson phone model no is 4186 something its not an ip phone.so can i connect directly to fxs port.how can i configure this scenario.
i have a configuration with me can anybody verify this and give me guide lines.any reply will be appreciated with good rating.
please seee the config below.
Router> enable
Password:
Router# configure terminal
Router(config)# interface serial 0/0
Router(config-if)# ip rsvp bandwidth
Router(config-if)# ip rtp header-compression
Router# interface serial 0/0
Router(config-if)# mtu 300
Router(config-if)# interface serial 0/0.1 point-to-point
Router(config-if)# ip address 192.168.19.0 255.0.0.0
Router(config-if)# frame-relay ip rtp header-compression
West(config)# dial-peer voice 401 pots
West(config-dial-peer)# dest-pat +14085553737
West(config-dial-peer)# port 2/0/0
West(config)# dial-peer voice 402 pots
West(config-dial-peer)# dest-pat +14085554141
West(config-dial-peer)# port 2/0/1
West(config-dial-peer)# exit
West(config)#
East(config)# dial-peer voice 901 pots
East(config-dial-peer)# dest-pat +19199588282
East(config-dial-peer)# port 3/1/0
East(config)# dial-peer voice 902 pots
East(config-dial-peer)# dest-pat +19199589595
East(config-dial-peer)# port 3/1/1
East(config-dial-peer)# exit
East(config)#
Thanks in advance
Regds
Binoy
Re: point to point voice issue
Is your routers configured with VOIP dial-peer?.
dial-peer voice 10 voip
destination-pattern 19T
session target EastrouterIP
dtmf-relay h245-alphanumeric
Let us know your problem.
Satish k
Bronze
you need to configure VOIP peers to each location. therefore for location A to reach B
configure on A -
dial-peer voice X VOIP
destination-pattern (Extension pattern of analog phone at B
session target: ip address of Router B
do the same from B to A, obviously changing the destination-pattern and session target to suite.
finally, on the FXS port itself where u connect your analog phone, you can configure the extension of the associated phone by performing the following
enter the associated voice-port (e.g) if phone 1 is connected to voice-port 1/1/0 and you want phone 1 to have extension 333 then
voice-port 1/1/0
(voice-port)# station-id number 333
then save.
109
