06-24-2006 02:46 AM - edited 03-15-2019 04:23 AM
Dear all,
i'm new to voice pls help me.
i have connected 2 offices using a p-t-p 128kbps leased line.routers are 2801.i have checked the connectivity
its fine.i'm using wic-1T for this connectivity on both sides. for voice purpose i have installed VIC2-FXS card.
my IOS on both sides are "c2801-ipvoice-mz.124-6.T2.bin".
and i have installed PVDM2-8 is installed on both routers.
my plan is to put 2 phones at each office.my phone is Ericsson phone model no is 4186 something its not an ip phone.so can i connect directly to fxs port.how can i configure this scenario.
i have a configuration with me can anybody verify this and give me guide lines.any reply will be appreciated with good rating.
please seee the config below.
Router> enable
Password:
Router# configure terminal
Router(config)# interface serial 0/0
Router(config-if)# ip rsvp bandwidth
Router(config-if)# ip rtp header-compression
Router# interface serial 0/0
Router(config-if)# mtu 300
Router(config-if)# interface serial 0/0.1 point-to-point
Router(config-if)# ip address 192.168.19.0 255.0.0.0
Router(config-if)# frame-relay ip rtp header-compression
West(config)# dial-peer voice 401 pots
West(config-dial-peer)# dest-pat +14085553737
West(config-dial-peer)# port 2/0/0
West(config)# dial-peer voice 402 pots
West(config-dial-peer)# dest-pat +14085554141
West(config-dial-peer)# port 2/0/1
West(config-dial-peer)# exit
West(config)#
East(config)# dial-peer voice 901 pots
East(config-dial-peer)# dest-pat +19199588282
East(config-dial-peer)# port 3/1/0
East(config)# dial-peer voice 902 pots
East(config-dial-peer)# dest-pat +19199589595
East(config-dial-peer)# port 3/1/1
East(config-dial-peer)# exit
East(config)#
Thanks in advance
Regds
Binoy
06-24-2006 04:02 AM
Is your routers configured with VOIP dial-peer?.
dial-peer voice 10 voip
destination-pattern 19T
session target EastrouterIP
dtmf-relay h245-alphanumeric
Let us know your problem.
Satish k
06-24-2006 08:24 PM
Hi sathish
thanks for your reply.sathish actually i dont know how to configure voip.as i told u i'm connecting the phones directly to fxs card.i dont know how to assign patterns if i just want to give 801 & 802 for my branch phones and 601&602 other office phones, how can i proceed with this. pls help sathish.
06-24-2006 07:07 AM
At that speed, I'd recommend configuring Link Fragmentation and Interleaving (LFI). Serialization delay is pretty bad at 128 Kbps.
06-24-2006 08:26 PM
i have only 2 phones on both offices.how can i procced with this can you give me a configuration sample.
06-25-2006 05:27 AM
You would need to add VOIP dial-peers so that the routers can send calls between each other. Lets assume that the IP Address of the East router is 10.10.10.1 and that of the West router is 10.10.10.2
East router configs
dial-peer voice 100 voip
destination-pattern 1408555....
session-target ipv4:10.10.10.2
West router configs
destination-pattern 1919958....
session-target ipv4:10.10.10.1
A couple of things on your existing configuration
1. On the existing pots dial-peers on both routers, take out the + and use just the numbers
2. The subnet mask of the serial interface doesn't look right.
Since it is a Class C network, usually the subnet mask would be 255.255.255.0, unless you are doing supernetting.
Are you able to ping between these two routers?
3. Also I would suggest that you take out all compression (ip rtp and frame-relay) for now. You can add this later after your the basic setup is working. You don't need to use both compression methods. Just one method is good.
Anup
06-25-2006 11:16 PM
thanks anup valuable information
Regds
Binoy
06-25-2006 07:37 PM
